TwinTurbo.NET: Nissan 300ZX forum - engine Upgrades question on all benifits
Subject engine Upgrades question on all benifits
Posted by mr300zxtt on August 05, 2013 at 11:21 PM
  This message has been viewed 415 times.
Message all this work is getting done in the shop already wanting to know all the positives and gains I should expect to gain. how much hp increase around?
Arp VG30 main and head stud kit (Nissan 300zx)
Nissan 300zx OEM Hydraulic valve lifters (24 new)
Wiseco Pistons 88mm over stock 87
Eagle/SCAT H Beam Rods
ARP Rod Studs
New Moly Coated Race Spec Main bearings installed
New Moly Coated Race Spec Rod bearings installed
New OEM Valve stem seals
New OEM Cam Seals
New OEM Head Gaskets
New OEM Oil Pump
New OEM Oil Pump Gasket
(Engine work)
ceramic/moly piston coating
Block Inspected and acid dipped
Block redecked
Block water passage bored out for more water to back cylinders
Block Bored and Honed
Crank center weight tig welded into place
Crank balanced
Block prepped and assembled
Heads inspected and cleaned
Heads Pressure Tested
Heads redecked
Ported exhaust and intake runners
5 angle radius cut valve job
Valve heights set
